As far as buying replacement clutch If you have all the parts you can get the field coil rewound and a new bearing if bad all other parts should be good.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
Just as an update, Spudder and I are going to use one of his tractors with a rear PTO and see if we can find some answers. Like if there are any interchanges, and if we can reproduce these rear PTO assemblies. Is anyone else interested in adding one to a tractor or getting one repaired?
Not to hijack the thread but I could use the upper double pulley on the clutch if anyone knows of a replacement?
you could as of year or so a go get them though warnen directly I got the hole assmbley but it was 580.00 bucks
Do you have a part number? I have a machine that is missing the complete clutch.
no I don't but I think they looked it up by application
Charles, I'm installing a rear pto on my 1772 and figured I should replace all the bearings back there while it was off the tractor. I took apart my clutch and found there is a spacer that keeps the rotor off the field assembly. Does yours have this part the Allen wrench is holding up?
DSCN0914.jpg I checked the air gap before I took mine apart and it is over 0.030". I think the silver shim in this photo is how you adjust the gap but it doesn't tell you anywhere what that should be. I will keep mine stock for now and see how it works. DSCN0922.jpg So far the bearings needed are: 2 - "6205" for the top bearing housing 1 - "6206" for the clutch 1 - "203KRR5 for the idler pulley 2 - ? rear pulley housing - I'm having trouble getting this one apart so it is soaking in PB for now
I did not have spacer. I cannot find it on parts list but I did get it working fine .
It is reference #AJ on page 5 of the installation manual. Thats great you got it working.
My mistake I do have the spacer. All works good now.
