Old 10-07-2013, 09:44 AM
Does it have a hole through it? Or is it solid? I agree, it looks coated, not brass.
Old 10-07-2013, 04:43 PM
digger350 digger350 is offline
yes its coated it just looked brass colored..has a hole thru it....its just puzzling
Old 10-07-2013, 05:17 PM
If it has a hole my guess is it has something to do with an oil gallery, but that is just a guess without the manual in front of me.
Old 10-07-2013, 05:44 PM
The valve covers have a collar on them......
I have taken motors apart and had stuff "show up" that I don't remember. Sometimes, it was stuck in the gunk that was covering the motor. Dropped there during previous work. If you can't find where it goes, I'm sure it will be fine. I wouldn't use any sleep over it. It's probably a spacer, or a sleeve. It sounds like you double checked all the dowels, so, look it over once more and see if you notice anything. Usually internal engine parts are not coated, so I'm pretty sure it's nothing that will cause a failure. Good luck!!
Old 10-07-2013, 05:54 PM
clint clint is offline
J-Mech I also seen on the PDF at parts tree of the head where the valve cover showed a very similar under cylinder heads part number 21. I'm not sure what else he can do now to identify the part other than find someone with a cub cadet same engine/or model or label each piece while inventorying parts and lay out to parts tree (or similar) pdf.
Old 10-07-2013, 07:13 PM
Here is a pic of the spacer in the valve cover on my Kawi. Does it look like this?
Old 10-08-2013, 02:43 PM
yep sure does look like it...i,ll check the valve covers
Old 10-08-2013, 02:59 PM
none are missing from the valve covers and they are smaller too..the search goes on..thanks
Old 10-13-2013, 06:54 PM
i finally found where that bloody collar was missing from.....it was in one of the bolt holes for the little black funnel thing under the oil filter on the outside....
Old 10-13-2013, 07:27 PM
Glad you found it, had to be making you crazy looking for where it went.
