Old 10-11-2013, 04:01 PM
Merk Merk is offline
Stock flat head engines like a Kohler will give you 7 to 7.5 to of you are lucky. A modified one may give you 8.5 to 9.0 to 1.
I wouldn't get too excited about high compression if you want a daily worker. The engine will be a pain to keep going.....been there-done that.
Project Uncle Dick
Cub Cadet 70
Old 10-11-2013, 06:09 PM
I agree!
Old 10-11-2013, 07:59 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
K301 engines are 6.1:1, 6.6:1 or 8.6:1 depending on which type of head design you have. most are 6.1 or 6.6 . K241 is lower 5:1, 5.4:1 or 7.1:1. anyway get it to hi and it won't start with a starter gen. come winter then you'll never get it started. our pulling engines use a starter cart. ford 8N starter on 12v. you have to get it spinning then turn the ign on.
now just so you understand what compression ratio is take bore x bore x stroke x 3.14 that gives you your cubic inch's. 30 or 491.61 cc for a K301, then you measure the combustion chamber of the cylinder head including the head gasket and the amount that the piston is short of the top of the block in cc's. then figure how many times you squeeze the bore into the head chamber.
sounds simple? ok now take into consideration how well an engine fills the cyl with air while running. or running compression. usually a bit higher than static. now this number is also affected by your cam timing or more important where your intake opens and exhaust close's. this is one of the reasons cam timing changes are noticed and can affect your performance. you look for that magic spot . make 2 degree changes either advance or retard . more torque you usually retard . more revs , advance. When I say advance or retard I'm referring from what's known as split overlap or when at TDC both valves are open the same amount. or the cam is installed straight up.
compression is the actual number of PSI you get when you crank the engine over. only reason its there is to judge the condition of the cylinder. you tell me you have 150 psi of compression that don't mean much . tell me you have 14:1 compression ratio , that tells me something. now tell me your engine has 14:1 comp ration and 150 psi of cranking compression then I can say that's kinda low for that ratio don't you think?
take it for what its worth. This would probably fit better in the pulling section but I got carried away.
Old 10-11-2013, 09:53 PM
EricR's Avatar
EricR EricR is offline
Don thank you for getting carried away, .
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
