Old 10-17-2013, 10:07 PM
vartz04 vartz04 is offline
Thanks just checked the tracking number and the switch should be here Saturday.
As far as the actuator it's a Warner 1000lb dynamic 2000lb static load actuator.
The bracket is just a piece of 1/4" plate that I drilled a couple holes in to match up with existing holes in the frame. I welded a stick of 1-1/4"x3/16" flat stock about 6" long to the plate and drilled a 1/2" hole to that. The rear of the actuator is hooked up to here using a 1/2" bolt and 2 nuts to sandwich the 3/16" flat stock
On the front I used the top hole of the implement lift bracket to mount the end of the actuator with a 1/2" diameter bolt.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 10-18-2013, 01:47 AM
TheSaturnV's Avatar
Nice find, looks like a great replacement option. As an aside, anyone have a club how much lift the original IH actuators were rated for?
Old 10-18-2013, 06:50 AM
Leadslingingdaddy's Avatar
You can go on the Johnny Bucket website and get lifts like that also....They have normal and fast acting (More money of course) lifts.
Old 10-18-2013, 07:18 AM
nice lift
Old 10-18-2013, 09:48 AM
This actuator was purchased used. I only paid $60 for it. You can get similar ones from northern tool.
Old 10-18-2013, 09:53 AM
cadzag72 cadzag72 is offline
I really like this actuator idea, I have a 147 on my wish list and this is probably the route I would go! can't wait to see it in action.
Ian
Old 10-18-2013, 10:23 AM
From looking at the specs the 1000lb actuators move at half the speed of the 500lb ones. Something to consider.
I have a spring assist on my tractor so this thing isn't even working to move the mower deck up and down. I need to put the back blade on the sleeve hitch and see how that works once I get the switch.
I'm taking the deck off tonight and changing oil and I'll throw the back blade on so all I have is some wiring left to do.
Old 10-18-2013, 06:56 PM
Hooked the back blade up and it lifted it with no issue. Still no. Video. It takes 2 hands to flip the wires around and the wife is Outa town. Should have the switch tomorrow and then I might go grab the brinly plow from my dad and see how it works out in the garden.
Old 10-18-2013, 09:45 PM
Are you leaving the lift handle complete or are you going to cuts it off?
Up to 534 and counting...
Old 10-18-2013, 11:26 PM
I'm leaving it complete for now. I want to use it for snow over the winter to make sure it'll work and then I'll cut it off..
Although I may be getting a JD300 and if that's the case I won't be using the cub for plowing anymore.
