Old 10-24-2013, 11:00 PM
I really hate that cub calls this a 3 point hitch. By all standards, it isn't a 3pt. The cat 0 is a 3 point hitch. I don't care what cub calls it, it will always be a sleeve hitch to me. I personally think it is confusing to call it a 3 point. Just my two cents.
Old 10-25-2013, 06:50 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Thumbs up
What J-Mech said......
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 10-25-2013, 02:49 PM
Berwil's Avatar
Berwil Berwil is offline
Instead of Frankenstein bolts, I made bolt in inserts for my 1450 out of grade 8 bolts. They are the same thickness inside the frame as the welded collar, just need a slightly longer rod to accommodate the bolt head outside the frame. I like the idea of having a solid rod in there rather than the stubs of the franken bolts.
Bill
Old 10-25-2013, 05:42 PM
Good idea!
Old 10-25-2013, 09:02 PM
bolivier's Avatar
bolivier bolivier is offline
Sweet, lookin' good
Old 10-25-2013, 09:22 PM
Numbnuts Numbnuts is offline
So if I was a dealer back in 1981 and a guy walked in and wanted a 782 with this hitch, would the shop had to custom make the franken bolts or some other setup to install the hitch?
Old 10-25-2013, 09:37 PM
Last price I saw on the Cub Cadet frankenstein bolts was $42 EACH ( I image they were less expensive in 1981 )
I can make the same style as Berwil make for his if you prefer that type.
Old 10-25-2013, 09:56 PM
Bill
That's a great idea!
Old 05-17-2022, 09:39 AM
Farmall450's Avatar
Ditto.
