Old 11-05-2013, 07:05 PM
Nightow1 Nightow1 is offline
Originally Posted by vartz04 View Post
Have a machine shop do the machine work and print out the service manual and rebuild it yourself. Its not that hard and there aren't many special tools needed
That is the way to go. I Started on cubs just over a year ago and my first task was a pulling tractor. After a lot of questions and online research I was able to do everything my self Minus the machine work on my engine. The rebuild was a lot easier than I thought. The people here and the past POST are a wealth of information someone is always there to help.
Good luck.
Old 11-05-2013, 07:06 PM
I own a mechanic shop....... So I do ALL my own work. (Imagine that.) With the exception of boring, and crank grinding, I can do it. Never was justifiable for the business to buy a boring bar.
As a mechanic, I don't like to see people rebuild engines if they don't think they are capable. Don't want to be the "Lone Ranger" on this advice, but I have seen too many times someone was "talked" into doing something that they had no business doing (either by someone else, or they "read on the internet" how easy it is) ..... Then had to pay me to fix it. There have been a few here, from this group, that did everything right on their rebuild, and it still failed. Personally, I say weigh the cost. If it works out for you great! If not, it comes out of your pocket. Everything we do here at my shop leaves with a warranty. So it's out of my pocket if it goes south. Sometimes, it's worth the dollars for the "insurance". If you feel comfortable, go for it! If not, let someone else do it. I will say, the only way that it is even remotely "affordable" to own and restore old tractors is if you do it yourself. Good luck whatever you decide! Sorry for the lengthy response!
Old 11-05-2013, 07:14 PM
J-Mech is right I didn't even think of asking you if you are comfortable or have any experience. I took all my projects on with knowledge behind me from rebuilding several classic cars. So I just had to learn the basics of small engines.
Old 11-05-2013, 07:15 PM
I am the same as the others have already said, but it kind of depends on my time. I have even hired a repair shop to do things that I can do, but just don't have the time to do. There is nothing wrong with hiring work to be done that is out of your area of expertise--I go to a doctor when I am sick, I go to the dentist when I need my teeth cleaned/fillings/etc., I hire a plasterer when my room needs plastering, etc. Just do what you can and hire out what you need to when you need to. In the long run, you will still have a quality-solid machine that will get the job done for many years. If you want to buy the junk that they sell now and try to pass off as quality, then I think you will be disappointed shortly thereafter. Most cubs will cost a fraction of what a box store one will cost, do a larger variety of duties, and will be able to be repaired for a lot less than the newer stuff that is out there. Also, as it was already mentioned, there is that satisfaction to think that you worked on your own tractor and accomplished something with your own two hands.....and to me, that is priceless! Well, that is my on the matter.
Old 11-05-2013, 07:54 PM
Errr, I know for sure that there are some parts (like the head) that have to be torqued with a torque wrench. I don't have one of those yet, and it's not something I would grab every time I need a wrench, so it's specialty for me.
Old 11-05-2013, 08:05 PM
I'm going to take this a little further.....
To accurately check the bore.... you need either: A bore gauge, or a set of "T" gauges and micrometers
To accurately check the out-of-round on the crank...... you need: Micrometers
To set crank end play..... you need: A dial indicator
I could go on. There really are a lot of special tools needed to properly rebuild an engine.
Old 11-05-2013, 08:44 PM
gmbadgley gmbadgley is offline
And nothing says you need to jump on a tool truck and drop $500. You can buy used tools at garage sales, craigslist, Ebay etc. I would bet $100 would buy everything you need.
These are small engines, BASIC tools is what you need for 99% of what you will do.
Old 11-05-2013, 11:40 PM
johncub7172's Avatar
I wanted to add to this. A lot of folks say a change of piston rings and a oil change is a rebuild. Not so at all. I was not quite old enough to understand rebuilding these small engines. And sure as heck was not going to learn on my own equipment. To start out with, and not knowing anything about a rebuild, I chose to have the rebuild done while the engine still ran good. Next, with the super help from OCC, I made a choice of who I thought would be able to do such a job. I was shown more about rebuilding a k241 than I ever thought imaginable. That is at least a base, and I will now try a k161 rebuild in the future. My warranty on this rebuild was one man's good word to another man's good word, and a handshake. That's how I do business.
About the tools, It would be easy to drop a large sum on quality tools. I bought a lot of Snap On, and you better believe I was making money with them. I had not one tool for a rebuild, and did not know apples from oranges. The measurements of the engine and components tell you what to do, not you tell the engine what to do. That has been my great experience. And I will be happy when I fully learn and understand myself one day!
{ no J-Mech, this is not at you or anyone}
The old IH, and Cub Cadets are well worth repairing. If someone is scared to work on these indestructible engines, then look elsewhere for engine service because that service shop is lacking serious knowledge!
Old 11-06-2013, 07:39 AM
sawdustdad's Avatar
My approach is that this stuff is supposed to be fun and educational. At first, I was hesitant to tackle an engine overhaul, but I eventually did one as I gained knowledge and experience. I just pulled my first hydrostat apart the other night. Learned a lot in the process. So, as others have said already, do the things you are comfortable with, tackle something new each time, and your skills and enjoyment will grow over time.
Old 11-06-2013, 08:41 AM
I do everything myself except for the precise machining. I take that to the experts.
