Old 11-15-2013, 10:50 AM
jimbob200521's Avatar
I agree with the others, you don't NEED a fuel pump but the way I see it, for less than an hours time, a couple beers, and $40, you could replace it and never have to worry about it again. This is the one I put on my 682 because it had a bad fuel pump when I got it like yours does and I haven't had a problem with it since.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
-Ryan
Old 11-15-2013, 11:26 AM
If you were spraying carburetor cleaner down the intake of the motor, then THAT is where the brownish liquid puking out the carb came from. NEVER spray carb cleaner down the intake of a motor, unless you take the plugs out and crank it before you try and start it. Even then, I wouldn't suggest it. Your just flushing all that junk INTO the motor, instead of getting it out. Not saying you don't have something wrong with your engine, but what you did with the cleaner is what made it puke. It doesn't take much liquid in a motor to make it puke. Carb cleaner is not starting fluid, and when it washes all that gunk in the motor, it definitely will flood it.
Start your diagnosis over. This time without carb cleaner. Or, if you want to clean it, take the carb OFF the motor. It may have a sticking float. No, pulling the fuel pump wouldn't have hurt it. Like I said, check the carb, I'd say it's a float issue.
Old 11-18-2013, 09:09 AM
SGragg SGragg is offline
Inactive Member
Smile
Bought a section of fuel line and bypassed the fuel pump. Removed and cleaned the plugs. Cranked the engine several times w/o plugs to eject all liquid from the combustion chambers. Reinstalled plugs and cranked 'er up.
Voorroooom!
Engine sprang to life and ran like normal. Mowed some leaves in 40 MPH winds just to satisfy myself. After cleaning leaf matter out of my ears, I was satisfied and quite happy to have my mower back among the living.
Sincere thanks to all for your advice on the pump and carb cleaner, etc.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 11-18-2013, 11:34 AM
That's great news!
Old 11-18-2013, 01:41 PM
Voorroooom!
Hope you also changed the oil and filter if it has one. Oil probably has gas in it, not good for bearings.
Old 11-18-2013, 02:13 PM
Inactive Member
Yes, per OAK and my previous posts on page 1.
Oil came out accompanied with gas. Ugh!
Stanton
Old 11-18-2013, 05:04 PM
Very good. Give it another change soon and you should be good.
