Old 11-24-2013, 10:25 AM
I just bought a thrower from mrcubcadet and it has teflon coating sprayed on the chute and auger. I haven't had a snow yet to test it out, so I really don't know how well it works.
Old 11-26-2013, 11:52 AM
V30crewcab V30crewcab is offline
what about the graphite paint from tsc?
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 11-29-2013, 09:17 AM
Redblower's Avatar
Redblower Redblower is offline
I think that s what was on my H42 that I just got this year, kind of a graphite gray color? Like on a plow it seems to wear off in high rub areas like the edges of the auger but I haven't had any sticking issues. Course it's been in the low 20's here since it started snowing so sure that has something to do with it. Probably wont' be a problem today as it's about 7 out there right now!
But I'm curious too?
Vic
Old 11-30-2013, 02:27 PM
JRJP56 JRJP56 is offline
A well painted housing and chute goes a long way and probably lasts longer than any teflon type coating, I use implement paint that is available at tractor supply.
Old 11-30-2013, 02:54 PM
macman81's Avatar
macman81 macman81 is offline
ill add my .02 and also recommend graphite paint. i use the ez-slide from farm and fleet but I'm sure any will work good. thing i like about it is $12.00 per quart and i can brush on a couple coats and throw the brush out. i imagine the more coats you apply the longer it will take to wear through but haven't used long enough to know that for sure. cheap and effective.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 11-30-2013, 03:28 PM
Muzzy Muzzy is offline
Thanks guys for all the replies. I just bought a product made by PB Blaster called dry lube. It claims to be a long lasting, waterproof, lubricant that can be used on almost any surface. I'm going to give it a try and see if it's any good. It comes in a spray. I got it at home depot.
