Old 07-24-2014, 10:51 PM
gdheck's Avatar
gdheck gdheck is offline
Ok guys, I never did anything with this, but I just bought a 2072. Can someone please give me a picture and measurements for the extension kit for mounting this on a super?
I will be adding a Ruegg 3 point to the 2072. Will it still have the rear brackets built in for the blower?
Thanks,
Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 09-11-2017, 05:42 PM
lannyjoe lannyjoe is offline
Smile 195-364-100
I have a model 1811,and I have the same blower 195-364-100 mounted on it, works great
Old 05-27-2022, 03:57 PM
Farmall450's Avatar
Originally Posted by riesedesperado6170 View Post
I think they are the same thing I think 195 is number that mtd you after they but out cub and is the IH atleast that what I was told buy a guy that works at my local dealer. do you have pic of yours so we can see what you have? and if you have a 3pt you may have part of the rear hanger brackets you need and the other part is just a 2" angle peace that you can make.
Yes, the CCC made one has a 195 tag.
Similar to the "60C" deck maybe?
Old 12-04-2024, 11:51 AM
yodaddy yodaddy is offline
Thanks,
Geoffrey
I know this thread is over 10 years old, but by any chance did you get the 364 running on your 2072? Reason I ask is I have a 364 I am mounting on a 2072, and there's barely any info or pictures out there, and I can't find a 421 extension kit.
I have the PTO all sorted out and pulleys aligned, and have some Cat 0 lower links (703-0437), but can't find anything showing the length of the angle steel that bolts to the bottom of the Cat 0, and the position of the blower arms mounting hole in the same. Also need the length of the hangers, and are they slotted or not? Also need to know how far the blower drive shaft cover is from the front of the tractor. Gravity pulls mine back leaving 1/2" of clearance, and it's making me nervous.
Any help would be greatly appreciated.
Thanks,
Rick Harris
2072 - mower and snow blade
1811 - Sims cab and 450 snowblower
127 - mower, snow blade, and QA36A snowblower
122 - snow blade, york rake, and log arch
Old 12-04-2024, 09:39 PM
Ozcub's Avatar
Ozcub Ozcub is offline
You may be better off sending a PM to the guy for your answer
Oz
Old 12-05-2024, 03:29 PM
This may help
https://www.cubcadet.com/en_US/conte...524c4f791e19/y
Old 12-26-2024, 10:11 PM
Thanks for the link. I'd seen that before, however it doesn't show the lengths of the hangers and other parts. I eventually muddled my way through and successfully mounted the snowblower.
Thanks again.
