Old 12-14-2013, 02:34 AM
clint clint is offline
Originally Posted by FrankF3 View Post
Clint, when you replaced the pads that were riveted, you simply drill out the rivets to take the old pads off or were they glued as well?
They were riveted on, I drilled the head off rivet punched it out and glued new pads on. It would be just as easy to rivet new pads if you wanted to use rivets instead of glue use your old pad as a template. Drill the head off the rivet from the back side of the brake (metal part) you can also grind the rivet head off the rivet head is really soft.
1440
1282
1604 cast rear/transmission (582)
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
