Excellent work!
I know this is an old thread, but I have the same situation. I am only able to find the splined coupler with 1 1/2 inch OD. Any thoughts on where I can find the 7/8 13 spline with a lesser OD, or did you buy a larger one and turn it down?
Did you try our Sponsors Patton or Houtz ???
I believe you will need to use the 1.5” OD coupler. This will need to be done by a machine shop. You have to bore the old splines out of the fan and turn the OD of the coupler down to press into the fan ID.
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
but need grinding outside and the thikness it's smal, may be 3/4 , 7/8 but it's one possibility , i have repair my 451 with that . I speak in french apologize for my english ! |
Looks good. All the more reason I need a mill/lathe
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
I repaired my splined shaft and it just broke again .It lasted maybe 2 winters. Is the splined shaft you used hardened and where did you get from .. Mine came from surplus center in Lincoln NE ..It surely should last longer ..what did do wrong
thanks |
