Old 12-18-2013, 10:30 AM
OR....look for a 1806.
Here is one
http://newlondon.craigslist.org/grd/4220035833.html
Up to 534 and counting...
Old 12-18-2013, 11:07 AM
I want one BAD.... but that's a little steep, even considering the condition.... wrong color, no decals.... and that stack, what's with that? Does it even have the M-18 in it anymore? Just sayn.
Old 12-18-2013, 12:46 PM
Leadslingingdaddy's Avatar
Older Case tractors had them....I just seen 3 at an auction today.
Old 12-18-2013, 01:13 PM
I think they had the "wide base" block in the case though didn't they? They won't fit in the cub. There were two different K341 blocks. A narrow base, and a wide. If there were others I don't know.
Old 12-18-2013, 01:19 PM
cubs-n-bxrs's Avatar
I just bought one of them 341's last week for $20 from a friend of mine. It had been in a flood but was very saveable. It had the wide base block bottom. I traded it to someone else for a very low hour HH100 Techumsah engine for a MF10 I am going to restore. I didn't check the block bottom but wonder if a cub oil pan would fit one.
Old 12-18-2013, 01:31 PM
JD's and Wheelhorses use the same oil pan setup ,but to use it in a cub I was told you need to weld up the block,then put a cub one on it.PTO end is larger than a cub also.
Old 12-18-2013, 01:33 PM
Kelly,
That question was brought up here not too long ago, Don Voit (dvogtvpe) said the blocks are different. I didn't know that until then. As many engines as he's rebuilt, I'd say that is correct.
Post #'s 5,6,7.
http://www.onlycubcadets.net/forum/s...ad.php?t=27733
Old 12-18-2013, 01:34 PM
PTO end of the block? Or the crank?
Old 12-18-2013, 01:35 PM
Pto end of the crank.
Old 12-18-2013, 01:38 PM
That's fixable though. Turn it down, or swap cranks.
