Thanks everyone...
982 with 3 PH, rear pto, front & rear hydrs & ps, 1772 w/3 point, rear PTO, 86, 2 Haban 60" decks, Haban 54" snow/dirt blade, Brinly Cat 0 Disk, 5' blade & 2 Cat 0 Plows, SpeeCo Cat 0 plow, Sears cat 0 Cultivator, Cat 0 CC 442 Tiller, 60” rear mower, 450 blower |
My 1872 has the oil sentry system....unplug the green wire from the sending unit and see if you have spark. Or the 3 wire connector on top of the engine.
![]() Quote:
I had a bad ignition switch that caused the same problem your describing. However it was on a 1541, others have more experience than me on a 2072... it's at least something to check, and the kill wire mentioned in previous post should bypass all safety switch for testing purposes. Good luck I despise troubleshooting electrical issues.
1541 (2) 1440 1282 1604 cast rear/transmission (582) 149 1450 (2) JD317 54" blade JD318 Ford 3600 |
![]() Quote:
![]() Quote:
![]() Quote:
Josh Diesel Cub Cadets........... |
My 1872 also has the oil sentry decal on the shroud.
My 2072 had it but the engine was the 18 magnum from a 1862. My current 1872 has the oil sentry thing as well
I just want to make sure that we are giving correct information. I have seen the decal before on machines I have worked on, but I believe it is just in reference to the fact that the motor has an oil pressure monitoring system. As far as what I have seen, there is no wiring that connects the oil pressure sender to the mag kill wire. The wiring diagram backs this up. Can we confirm? Again, just trying to make sure info is correct. We don't want someone trying to chase an electrical circuit that doesn't exist.
