garnold, I put a creeper in my 148R build. I took a 14hp out of a 147 and put it in a 108, hence the "148" designation. I don't see any problem with that, you won't break the creeper. As J Mech has explained, it will only see the torque needed to spin the wheels, which isn't that much in most circumstances.
I'm no expert, but it's hard for me to see the creeper as a weak link in the drive train other than for the fact that it has more parts that can break. But a properly lubed and adjusted creeper should take anything the tractor is likely to see, regardless of what engine is in it.
Thank you guys for all this information :-)
Here is a pitcure of the internals parts in a creeper for those who haven't seem the inside of creeper: http://www.cubcadet.com/webapp/wcs/s...0-A/0098100017 A IH Cub Cadet without a creeper has a drive shaft going into a coupler that goes into the imput shaft in the trans. A IH Cub Cadet that has a creeper has a shorten drive shaft going into a coupler them imput creeper shaft #7. The creeper shaft has a small gear which Cub Cadet calls Direct Drive Coupling #9 that a shifter collar #10 and connects the power to driven coupling assembly #6. Weak point is the direct coupling #9. Now if your is using creeper the shifter collar #10 moves over planet carrier assembly #11. The planet carrier assembly #11 has 3 planet gears #12 that spin around an imput shaft cage #16. The shifter collar #10 engages the gear on the planet carrier Assembly #11 and connects the power to to the driven coupling assembly. The weak area is the 3 planet gears #12. One other area that can cause problems is the creeper shift yoke #23. Wear points are where the creeper shift yoke #23 rides against the shift collar #10. As for not having a direct drive......you have a shift collar #10 that moves plus the gears that are not big enough to do the job. Sounds like a wreck waiting to happen. You can put 14/16 horse power engines in your Cub Cadets. It's hard to use all that power to the ground unless you put some time and money into the clutch. Been there done that. The only time I had drive shaft pins break is driver dumping the clutch or hole pin goes into is egg shape and the best one is using a wrong/cheap pin. Its your Cub Cadet.....install a creeper if you want to....I wouldn't.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Merk Well said. Once told to me back in my dirt bike days by a Bultaco dealer "If it ain't there it can’t break" lesson learned. Just my 2 cents and I have never owned a creeper but it looks from a design standpoint like a problem looking for a place to happen. I would only use one if I was running a blower or a tiller. Again just my 2 cents. Please don't hate me for this.
Good explanation Merk.
When the creeper is used within its designed capabilities, it'll be fine. Start adding power, bigger tires, pulling excessive weight, etc is where you find the weakest link. At one time, I had a 122 with creeper and a 125. Personally I liked the 125 ( hydro ) better. I had slow when I wanted slow and faster with a push of the lever. That said, it's also why they make chocolate and vanilla ice cream
i concur, like said, I only use it with my tiller.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
The Direct Drive system found on a IH Cub Cadet started with the 70/100 Series, and was a major selling point for IH Cub Cadet. A under-drive unit was needed to slow the tractor ground speed down to allow for higher engine R.P.M operation, where one can now successfully and effectively use IH Cub Cadet approved implements such as the snow blowers, Sweepsters, Mott mowers, sickle bar mowers, and tillers. However, there is no substitute when it comes to having the most possible amount of torque transfer with the least amount chance of failure than that of the mechanical energy transfer system: {direct drive no under-drive} gear drive transmission. It has been suggested to me, that operating a IH Cub Cadet equipped with a creeper gear for such uses other than the IH recommendation of use is not recommended. My thinking on using a creeper would be good for everything but having a tug of war on concrete, and pulling a 10 inch bottom plow. Again, just what I think I can use a tractor equipped with a creeper for.
Make doubt, a gear drive with creeper or with out creeper is the best complement to a hydro drive IH Cub Cadet. The fact that someone can make a gear drive even slower sounds pretty neat. I wonder how that is if not than more than one creeper unit is on board in full operation with lower gear ratios : of course! Six inches per minute,..........
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
Like I stated, I don't disagree with anything posted. It is definitely a weak point.
![]() Quote:
