How often do yo really replace points because they wore out?
It's not a lot of money granted, but I don't really think you gain much with it. |
Yes I agree,but it does have a flashing light!!!
That is a cool feature!
Most of the 'dedicated Pullers' all have them. They swear by them as a must have. ?, NIK,
It dont cut grass, but its yellow. |
I've only ever replaced two sets of points on all the cubs I've bought/sold/owned. But you never really know when they will go bad so can't hurt to upgrade.
John, PROUD OWNER ![]() Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow, 1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
http://www.onlycubcadets.net/forum/s...ad.php?t=25587 Post #6 Don is pretty big into pulling...... |
![]() Little gizmos like the point saver makes logical sence? Yes vs. no? Can't hurt? Back in (yikes) 1978 I added a electronic ignition on my 1970 Buick skylark. A box that was aprox., 6" x 6" x 2" that was supposed to do the same thing as the point saver in question. Even back then it did its job. So adding a point saver to dedicated points can't hurt????? ![]() NIK,
If my memory serves me the condensor gets taken out of the equasion as well. I have a point saver setup in the basement and will be installing it on something in the spring as well as the bosch blue coil.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
when I got my 128 the points were bad and no connection . I take a point file and rub or file some silver solder or silver , this coats the steel some ,then file the points and check with a ohm meter ,it has been firing up fine for 4-5 years now
The little flashing light on the points saver works really well timing your tractor , especially for us older guys that do not see as good as they used to , and can't crawl around their tractors like they used to do !!!!!!
I like mine a lot , especially when I bring home a new tractor. I mount it where I can see the light flash when I am timing it. For the most part , I am a one man show when I work on my tractors and every shortcut helps. |
