Old 01-19-2014, 09:42 PM
ClickClickBoom ClickClickBoom is offline
How does the reverse work on the foot controlled 1250?
1872 W/ Kwik Way loader
1650 W/ Dual Hydraulics, and rear lift
Cadplans Caddigger
qa36a blower, tiller, and snow blade
Gannon Earthcavator
Old 01-20-2014, 09:32 AM
gophred's Avatar
gophred gophred is offline
Pressing the top of the pedal goes forward, pressing the bottom goes backward. With the current linkage positions, It is set so I can comfortably rock the pedal all the way forward. The pedal is flat and it takes a lot of ankle bend to get full reverse (not sure you really need that). I am waiting for better weather to play with it, I think I am going to put some sort of a block for my heel to press on when I want to reverse. I did have the 1250 out in the snow yesterday. Wish I had video. I had the rear end sliding out enough to steer with the slide
Gophred
2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower.
Old 01-20-2014, 09:12 PM
might look into a foot control from a tractor that actually was from the factory. I think most of them were a U shape to facilitate reverse.
Does yours return to center when you let off, or what happens?
Been wanting to do this before I put the FEL on the cub. too many levers.
Want to fab another set of brackets? cost?
Cadplans Caddigger
Gannon Earthcavator
Old 01-25-2014, 03:29 PM
gophred's Avatar
The foot pedal does not return to center when you let off, you have to press the brake pedal and that will return it to center. With everything lubed the brake has way more leverage than the new pedal and easily moves your foot to center, even if you don't lift it. I was looking at it and figured a strong spring pulling the new lever straight up would probably get it back to center (or most the way) but I don't think I am going to bother.
Sorry I fabricate this stuff largely by hand and the machining I do is on borrowed time, so I am not in a position to fab them for sale
Gophred
Old 03-08-2014, 05:57 PM
gophred's Avatar
Default Cub 129 foot pedal speed control - new pics
Here's a few pics of the foot pedal speed control mod on this 129 (all shiny). It has hydro lift, so there was a little less room. It still went in about the same as the 129 with manual control, but the lever on the rod going to the pedal had to be a little shorter. The picture onthe left is shot from the engine area the pic on the right is from the seat area
Gophred
Old 03-09-2014, 09:25 PM
Looking good! Thanks for the pics.
Old 03-09-2014, 09:33 PM
Nice!
Old 03-12-2014, 07:11 AM
sawdustdad's Avatar
beautiful work! I want one!
Old 04-21-2014, 06:31 PM
snoel's Avatar
snoel snoel is offline
I want one on my 149. Could you post pics of the foot control (right) side? I had already been thinking of this mod, and then I saw yours. Made it look simple to fab.
Thanks,
Steve
Old 04-22-2014, 02:35 PM
texretvet texretvet is offline
I REALLY want to do this on my 2182!
CC 2182 w/ Cat. 0 3pt. lift 54"GT deck
IH CC 1450 w/ CC #2 tiller and 44" deck
