Old 01-13-2014, 09:06 AM
Mine too...
Old 01-13-2014, 09:28 AM
jimbob200521's Avatar
Interestingly, the parts books don't show the shims on the gearbox, but my QA has them too.
Mine too...
Well that makes me feel a little better My thinking is that they're there for angle adjustment for different series Cubs since they are "A"djustable Or possibly there to take stress off of the u-joints by backing the gearbox out an inch or so, but I don't see how that would make any difference, really. And I see your point about stress on the mounting flanges but at this point I either do it this way or the belt shreds, it really was a pretty good bit out of kilter. I will, however, keep a close eye on it.
My question is, is both of your throwers the QA-42A or just the QA-42?
And darkminion_17, what's your thrower mounted on?
-Ryan
Old 01-13-2014, 09:42 AM
I have 3. A QA42A, a CC42 and a 450. The CC is a different gearbox. Looks similar, but the mounting flanges are different.
(OK, well the QA42A is my brothers, but I've been using it. )
Old 01-13-2014, 09:57 AM
I did a little digging and found someone else who's made a shim for a 782 with a Honda repower (different beast I know but it adds credence to shimming the gearbox). And yes I know; he kept it mounted flat, but check out the other link I posted below. Scroll down, you'll see pictures.
http://farmallcub.com/phpBB2/viewtop...art=15&t=14796
And here's one more link I found that shows someone had to make custom spacers to make the QA42A fit on a 782 because the engine is angled up at the front about 3°. He did it slightly different but the end result was the same; an angled gearbox
http://mgonitzke.net16.net/QA36A.html
-Ryan
Old 01-13-2014, 12:22 PM
Mine is mounted on the floor in the wood shed.
I guess after 40 years the qa mounts get bent from hitting stuff.
Old 01-13-2014, 12:31 PM
Are you talking about the bolts that stick out of the frame that the quick attach arms slide over? Mine actually did, too recently. To solve the issue, I just slapped a couple large washers on the outside of the bolts to hold the quick attach arms in place and bam, good as new
-Ryan
Old 01-13-2014, 01:23 PM
mortten mortten is offline
Mine has 2 shims on both the top and bottom. It's on a 1250.
