Old 01-14-2014, 09:42 PM
rdehli rdehli is offline
Default QA 42 Belt adjustment
my belt on my QA 42 A Thrower keeps working loose any suggestions it really works loose in the wet heavy snow . thanks much
Old 01-14-2014, 09:53 PM
Need an extra 1/2-13 LH nut?
I think you're supposed to loosen the bracket, make the adjustment and tighten everything down. Is corrosion keeping the bolts from getting the adjustment plate tight? Is the cotter pin on the bottom of the 1/2-13 LH castle nut in place?
Old 01-14-2014, 10:46 PM
Jeff, are you talking about the plate the gearbox is bolted to? You don't have to loosen anything up, just turn the adjustment knob. There is supposed to be a locking arm attached to the frame to hold the wing nut from moving. I don't even use the locking arm. Mine never moved.
Old 01-15-2014, 01:13 AM
cubby102's Avatar
cubby102 cubby102 is offline
The one I had had 4 bolts that you loosened then you make the adjustment and tighten them back down
Old 01-15-2014, 09:46 AM
Berwil's Avatar
Berwil Berwil is offline
I always loosen the bolts to tighten my belt, mainly because the bolts were loose when I got the blower. After reading on here that there are spacers and you don't need to loosen the bolts, I tried it this yr....it didn't work. It's due to the rusty plates and spacers. If you have a clean unit tightening the handle alone may work, if it's a bit rusty, try loosening the bolts first.
Bill
Old 01-15-2014, 10:38 AM
my blower is real clean and rust free , the adjustment t handle just seems to work loose,. especially in wet heavy snow when the thrower really is working.
