![]() Quote:
-Ryan
I just bent my straight bars and welded the hole shut and redrilled it maybe 1/4-3/8 closer to the end.
It works good on my 782. The upper straight bars will not let the blower come all the way up as they will hit on frame flare out, thus the bend. Think there is a curved set on evilpay now. |
![]() Quote:
Well, I ordered a set of lift bars from CC Specialties and got a pulley ordered from McMaster, stopped by the local CC dealer and they had the IH belt in stock so I picked it up. Hopefully I'll have everything by the end of the week so I can get it running.
Thanks for the help!
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
I never knew I needed to do the conversion, I'm sure I was running it on my mtd 20/50 (totally different brackets) then my 129
Maybe too late now but you said you had a running 1250 and a 1650 that did not.rather than switch the lift to the 1250,put the 12hp engine in the 1650.It would bolt in and the blower is made for it.Just my two cents worth but the engine swap could be done in a few hours .
Bob |
*Sigh* well, snow storm is here.....belt is here....pulley is here......lift arms haven't made it yet....
![]() Quote:
I am a little late but you can run with the straight bars but can only raise an inch or two. In a pinch I would.
I have used my QA 42 A on my 782 for the last 3 winters now and really like it . The only thing I did differently was , is put a smaller diameter pulley on the gear box. I now use a 4" pulley and a 31 " belt with no issues what so ever, it lets me throw the snow a bit further 15-20 feet with no issues. the main reason that I changed the pulley , was that I could not find a stock 5/8 pulley for the thrower. The only time I have issues is when we get 6 or more inches of wet heavy stuff. Then all the throwers in my area have trouble.
