Tip of the hat sir, good job. Great pictures and write up.
Wow, what a nice job!
![]() Quote:
Thanks! Vic |
Thanks guys. I do have a degree in welding and fabrication engineering, it helped a little.
![]() FFGino, I with you. I don't have that much time in, but I've worked with plenty of "engineers". The more initials they have in their title the less common sense they have! 1811woody, I don't know capacities yet. Haven't done much with it, too stinkin cold. I do know it lifts my 160 lbs at a fast idle no problem. I would guess a few hundred lbs max. If I recall, quietline lift cylinders aren't all that powerful. I assume it would pick up the back of the tractor pretty easily if I block underneather the arms and push down. Probably make taking chains on/off easier? ![]() mjsoldcub, I agree. I don't like the look of the plate across the back either, I like to see things working. I would love to start turning these out, but I don't have a shop to do it in anymore. I left my job two months ago to raise my then 3 1/2 month old daughter so my wife could go back to work. I'll work on gettting measurements and a few drawings together. Thanks again for the kind words Bill |
Great job Bill. I've thought about building a Cat 0 for one of my Cubs someday.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
very nice work.
now get that tiller on there!! we need action shots
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
![]() Quote:
Speaking as a 20+ year machinist, I respect your work.
You got my vote, Very nice work.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
![]() Quote:
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
