Old 02-05-2014, 10:33 PM
ricks ricks is offline
I think I remember seeing the testing procedure for a coil on here somewhere. I'll give that a look-see. Thank you.
Old 02-05-2014, 11:55 PM
From what you said you've tried and had no results, I would try a new condenser.
Old 02-06-2014, 12:13 AM
Juicybusa Juicybusa is offline
Based on additional info I second the condenser suggestion
Old 02-06-2014, 07:44 AM
Pswan Pswan is offline
A different angle, unless I misread the above posts, could be weak/broken valve spring or carbon clogged exhaust valve. Engines with valve float/burnt exhaust valve won't rev too. My two cents.
Pete
