Old 02-14-2014, 04:07 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
put external brakes on it.
Then split the brake pedal pad in half so that you have individual rear wheel brakes when you want them.
With chains on, you will have pretty good turning brakes.
Old 02-14-2014, 04:40 PM
hdsdcouple's Avatar
I would like to do that, have independent rear brakes.
Old 02-14-2014, 05:04 PM
Originally Posted by hdsdcouple View Post
so no on the faster reverse Gear?
No. Not unless you speed up the entire trans.
Old 02-14-2014, 07:16 PM
Is there a way to make a hydro go faster in reverse?? I dont know much about hydros but with the swashplates the way they are it seems it should go the same speed in reverse as going forward? Does the linkage limit it or am i just wrong? Havent really dug around much in there...
Old 02-14-2014, 07:19 PM
The swashplate is cast so that it limits the speed in reverse.
Old 02-14-2014, 09:23 PM
sawdustdad's Avatar
You could grind the nub on the swash plate to allow it to pivot more in reverse. Wouldn't be too big of a task.
Old 02-14-2014, 09:34 PM
It won't help much (if any). The casting on the internal swashplate won't allow for more travel. It has a "nub" on it that hits the case at full travel.
Or did you mean on the internal swashplate? If so, that is not a good idea. Besides, then you would have to make the slot in the dash longer. NOT worth the work of disassembly.
Old 02-14-2014, 10:39 PM
Flip the rear ring gear and you can have 3 rear speeds and one forward....yehaa
Up to 534 and counting...
Old 02-14-2014, 10:50 PM
LMAO!
Sometimes it's the cool ideas....
Old 02-15-2014, 08:08 AM
We have a winner! Leave it to Lew!
