Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 02-18-2014, 08:09 AM
V30crewcab V30crewcab is offline
I put a relay in for the glowplugs, so it gets 12volts right off the battery instead of the 9 it was getting. lights right off now.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-18-2014, 04:08 PM
sawdustdad's Avatar
Wolverine makes adhesive heater pads that stick to the oil pan and plug in. Couldn't be easier to install. I have them on my boat's engines (slightly larger than your engine.)
Old 02-19-2014, 09:39 AM
gt383mag's Avatar
gt383mag gt383mag is offline
have thought about that also
Old 02-19-2014, 11:08 AM
red56turbo's Avatar
I'd check the voltage going to your glowplugs. I would think when pretty cold, after 60 seconds, it would atleast attempt to fire and go. Todd's idea on the starter would prolly help out tons as well.
Todd,
On that starter, did you have to modify the motor mount by drilling a hole for the positive post?
Josh
Diesel Cub Cadets...........
Old 02-19-2014, 03:42 PM
Josh, yes I had to use a hole saw and cut the hole. I hate doing that but I had no choice. I followed Todd M's guide. I wish someone would make a starter that would just bolt in place.
Old 02-19-2014, 03:47 PM
Just as a side note: I have never seen a glow plug that wouldn't swell the tip at a 60 second cycle time repeatedly. WAY too long if you ask me. If they are getting 12V, 15 seconds MAX should be plenty. If you have ever battery tested one, they start glowing within seconds.
Old 03-26-2015, 08:07 PM
EarlJ's Avatar
EarlJ EarlJ is offline
I have a few questions first. If your tractor still uses the original dash indicator that is problem #1. If you did not do the glow plug upgrade that is problem #2. If you did not replace the starter with a gear reduction type, even the cheap $89 China made POS ones that I use, that is problem #3. If you did all that and it still won't start, give it more throttle. Mine will start at about 1/3 but I hear some guys almost go wide open. What temperature will yours not start at? If I'm no help see if my man Vic can help ya out. http://www.orangetractortalks.com/20...starting-tips/
Good luck.
Hey Todd, what is the workaround for the glow plug indicator light?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 03-28-2015, 10:29 AM
gt383mag's Avatar
a ford starter solenoid hooked to battery and other end to glo plugs use the original wire to glo plugs to trigger the solenoid it dont exactly bypass the dash indicator but it puts 12 volts to the glo plugs... make sense?
