Old 02-21-2014, 11:31 AM
esarvey's Avatar
esarvey esarvey is offline
Default Tall tail ?
what I'm I missing here, I have a 15hp mag Kohler, pulling a 18hp , alum. rear, designed to turn a 23" wheel tire combo, efficiently ! I made the gear ratio higher, by adding a 27" tire combo, it's even more efficient for pulling a 12" plow, eight to ten inches deep in the earth !!! less wheel spin ! The idea is to move 1000 lb mass (including driver) + ground engaging equipment ! if a cast from a 17hp gas can't efficiently, with a 18hp diesel , I'll keep my gas mag's !! LOL
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 02-21-2014, 11:38 AM
Earl
What are you talking about?
Old 02-21-2014, 11:47 AM
esarvey's Avatar
Default 12 hp vs 18hp
If 6hp less is geared that much lower U can compensate with taller( more circumference ), did on race tracks, ( drags, asphalt , dirt ) worked fine same principal !
DaDuke of
Old 02-21-2014, 11:54 AM
Originally Posted by chevy13045 View Post
I misspoke. I meant how did they get around this issue on the 782 with cast iron rears. Thanks for the pictures. I will keep u posted on progress
782D's used a different fuel tank. Plus, they didn't have a cast iron rear. They were aluminum.
Old 02-21-2014, 12:09 PM
esarvey's Avatar
Default IH 782 17hp
IH built 17hp , were cast !
DaDuke of
