Old 03-01-2014, 08:03 PM
These are the threads relating to the engine and the build of the pressure washer.
http://www.onlycubcadets.net/forum/s...ad.php?t=27939
http://www.onlycubcadets.net/forum/s...ad.php?t=26834
http://www.onlycubcadets.net/forum/s...ad.php?t=28490
Old 03-01-2014, 09:10 PM
Those are nice setups!
Old 03-02-2014, 01:36 PM
Originally Posted by Bob95065 View Post
The trouble is the pumps are very expensive especially the larger ones. Most of the broken pressure washers I see need pumps not engine work.
Try your local pawn shops, they often times have good stuff for a decent price.
Old 03-02-2014, 02:08 PM
This is exactly what I was describing and didn't even realize it existed. I stumbled on this at extreme motor works site which this is for a pincor generator but same idea. I guess they beat me to it!!
Old 03-02-2014, 02:54 PM
Yep that would work perfect.
Old 03-28-2014, 10:58 AM
1811woody's Avatar
I am looking for a used pressure washer and thought that one could be made for a CC. If I made a mule drive bracket like the ones used on a snow thrower or shredder that drove a pressure washer it could be very useful. The trouble is the pumps are very expensive especially the larger ones. Most of the broken pressure washers I see need pumps not engine work.
If I did this I would want a very long hose to keep spray away from the tractor. Other than that it should be something that could be done. If anyone has done this can you post pictures or a link to a thread that describes it?
Anyway, it was an idea I thought I would throw out there.
I haven't made on yet but its in the plans I have the pump ,wand, hose, pressure regulator which I'm not sure I need I could just turn the idle down. I would suppose it would need an idler pulley that I think would be available at McMaster Carr I thought about using the extreme mount just haven't committed yet.
Old 03-28-2014, 02:44 PM
rdehli rdehli is offline
sounds like a good plan of attack, plus its nice and portable too.
