Old 03-09-2014, 12:34 AM
Very nice, and they look clean on the tractor
Old 03-09-2014, 12:50 AM
cubby102's Avatar
cubby102 cubby102 is offline
Nice. And those are almost bright enough to be used for headlights
Old 03-09-2014, 12:55 AM
Fireman72737 Fireman72737 is offline
Thumbs up
Those are pretty sweet and surprisingly bright
Always Looking for More!
Old 03-09-2014, 07:14 AM
I like that setup, well done.
Old 03-09-2014, 07:21 AM
yeeter yeeter is offline
+1, thanks for sharing!!
Old 03-09-2014, 07:50 AM
all 3 together draw less than 4 amps.
Don't you mean 0.40 Amps...???
Old 03-09-2014, 10:03 AM
scgtguy's Avatar
scgtguy scgtguy is offline
Default amps / lites
it works at 9~14V,0.1(A)
so x 3 = .3 (A)
you can almost breath on these and they light up. One note if you install in same place I did ... be sure your mount holes are centered ... otherwise the nut on back side may not fit properly, its a close fit .
B.
Old 03-09-2014, 11:08 AM
kostendorf's Avatar
If you use this switch you can turn your front lights on only or turn your back lights on only or turn all your lights on. The part no. is-- A-371465R91
Old 03-09-2014, 01:22 PM
They could be an option for the tractors with no headlights,,,,
Aim some forward, too,,,,,, better than no lights!!
Old 03-09-2014, 02:15 PM
scgtguy's Avatar
Thumbs up Switch part no. is-- A-371465R91
Kostendorf,
jeez ... perfect for my application with my stock headlites ... I may have to pony up for that item ! OOOEEE !!
Bryan
