Old 03-19-2014, 03:16 PM
I used to sharpen my blades until they were VERY sharp and they cut sooo nice... For a little while anyway.
I do believe that sharp blades are better for the grass, and I know sharp blades are better for the equipment.
If I had the time, I would still keep them very sharp.
I also believe that they should only be sharpened from the top side, the bottom of the blade should remain flat, although keeping the bottom flat is nearly impossible.
Although some of the blade sharpening equipment posted above looks very nice, I think an 8" bench grinder works very well followed by a few swipes with a sharp file, just to clean up the edge. I do have a floor model belt sander with a 40" X 1" emery belt, it will make a blade sharper than a butcher knife, but the belts wear out very fast and are a little expensive if you sharpen many blades.
