Old 03-22-2014, 09:08 AM
Originally Posted by gophred View Post
Sorry I miss read your post. here's the best pic I have of that area
That's a 1X9 dash.... Not a QL
They are different.
Old 03-22-2014, 12:38 PM
Bubbabk Bubbabk is offline
Welcome to OCC!
Thank you Acecil, Sam Mac, Gophred and Finsruskw!!!
Sorry about jackin up my post by putting it in the wrong spot. Like I said, I'm new and don't wanna create a buncha waves, just lookin for a lil help is all.
Using J-Mech's pic......
I put the Valve handle (6) back into the valve handle assy (4) which is attached to the chain link (5) but now I cant get the valve handle lever (6) to move at all, it won't lift or lower. I did notice I am missing the valve handle bushing (8) and the retaining ring (9), but even then I don't know if I have it assembeled correctly even if I had them.
I greatly appreciate the help, Been tryin to get this 1450 back together, I'm almost there....I can smell the victory......I just can't see the finish line.
I was hoping that someone had actual pics of how the valve handle, valve lever handle assy are put together.
Again thank y'all for your help in advance
Old 03-22-2014, 08:56 PM
Whaat, ...is the spool stuck in the valve? If Ya got everything back together and it won't move, that's about the only thing it could be.
Make sure the exposed part of the spool is clean, not rusty or anything. Soak it down with some WD-40 or like product and tap lightly while working the lever back and forth.Will the spool turn in the valve body with the link removed?
You do have just a single valve and not a dual set-up, correct?
Ya gotta tighten down the squeeze clamp really tight to keep the handle from spinning.
Best to use a grade 5 bolt to keep from busting it and your knuckles. You may have to widen the gap some if it has been stretched too far and is completely closed w/the bolt tight.
If Ya need a bushing and snap ring, I have some
