Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 04-15-2014, 02:48 PM
This may work for a fix, move the QA bolts to the forward hole(see red arrow). Cut the upper part off the mule drive mount, move it forward, weld it back together. You should then be able to use the bolt hole at the front of the frame along with the QA pins. Then use the old hole for the drain hole.
Old 04-16-2014, 11:11 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
That's a good idea too, Sam! Unfortunately this project is going to have to be put on hold(other than brainstorming) until I move and have a well setup garage.
Thanks for the excellent ideas fellas!
I am open to more if anyone has some, especially for the drive line angle issue.
I am going to order a Vanguard for the 782 to get that up and running quickly, I hope!
STAY TUNED!!!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-26-2014, 11:48 PM
Shrewcub's Avatar
Default Update!
I just ordered a SEW Vanguard last night for the 2072. Thanks for motivating me J!
I still have some measurements to take. But I think the Chinese diesel is going to go on the O.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 08-27-2014, 12:03 AM
bolivier's Avatar
bolivier bolivier is offline
Sounds like a plan. Looking forward to your progress.
Old 08-28-2014, 04:12 PM
Shrewcub's Avatar
That was FAST!! The Vanguard just showed up at work 5 minutes ago. I placed the order 50 minutes after midnight Tuesday. Can't wait to get it in there.
I will do another thread after I get it in there and put a link at the end of this thread.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
