Old 04-12-2014, 09:29 PM
sawdustdad's Avatar
I've been buying this seat for my cubs. I like the high back.
http://www.northerntool.com/shop/too...9222_200519222
It has the proper hole pattern for the seat springs, at least on all the wide frames.
Old 04-13-2014, 09:12 PM
Pipestem Pipestem is offline
What do you use to reline the brakes with?
Old 04-13-2014, 09:38 PM
I just bought the semi metallic heavy duty 1.25" strips, from mcmaster...can get a foot for like 4 bucks...then just used some sci grip (industrial epoxy adhesive) or could use jb weld and reef them in a vice
Old 04-14-2014, 09:49 PM
jcsmith jcsmith is offline
mjsoldcub, you can also sh tcan the plastic bushing in the top of tube. Use a 3/4 " id wheel bearing. When I did mine the bearing was a loose fit, so I wrapped a piece of aluminum duct tape around the shoulder and it fit tight. That and the nice 605 bearing upgrade makes a big difference. Can't wait to see the photos. Also, some guys are using a needle thrust bearing instead of the Nice 605.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 04-14-2014, 10:21 PM
Thanks...yes i got a thrust bearing, and will probably try to get it together tomorrow...i had to make a cam follower, wasnt going to spend 20+ bucks for one!!! Came out pretty good i think..heres some progress pics..i couldnt stand the way the steering column wobbled some so i made a little bracket with stainless u-bolt..dont know if you can see it in the pics with all the wiring in...finally getting to general assembly
Old 04-15-2014, 09:35 AM
That is looking real sweet. Is it a worker, or show girl? The white faced gauges look cool. I like that look.
Chris
Old 04-15-2014, 03:52 PM
Thanks, i appreciate it...it is a worker, although im gonna regret it...i am gonna take it to a couple gas/steam shows this year...i dont start out intending to do this (same as my truck) meant to get it running and use em, then i tear into em and spend so (too) much time and detail, and then dont want to use them!! I was going to wait til it was together and then go through photos and post a bunch...i do need to find a similar seat..no more than 12" high and with a steal back pan...really dont want to spend bunch of $ either...hooe my front tires come today...got the 1" spindles all done last night...just happened to get them with the new axle i got for 15 bucks..
