Old 04-17-2014, 01:53 PM
jchristensen jchristensen is offline
I have them on a John Deere deck and I think they are great. They really speed up your mowing time as you can drive faster. I've been thinking about getting them for my 42" Cub deck too.
The double blades on your 38" deck look interesting, Sam Mac. What kind of difference do you see with this set up? And how do you keep the blades in that position? Seems like the crossed one would want to move.
Old 04-17-2014, 02:02 PM
Well since Meg-Mo didn't make blades for my 38" deck with the short blades I figured since I had a set laying around I would try it and see what happened. Seemed to cut a little better. They did want to twist, thought about welding some stops on them then decided that could be a problem if they broke. Ended up going back to stock.
Old 04-18-2014, 10:47 PM
ccr147 ccr147 is offline
Sam Mac they do make them to fit my deck. The outboard blades are 16 and change and the inner blade is 17 and change (I forget the exact fraction). Apparently the 48" deck from 68-72 had different blades than the earlier model 48". I'm stoked I can't wait to try them out.
Curt
Old 04-19-2014, 06:43 AM
Curt
Curt
Don't forget the mandatory pics or you will hear about it, just trying to warn you LOL.
Old 04-19-2014, 10:53 AM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Sam,
If you had a different type of stop to keep the blades from moving in relation to each other instead of welding on the blades, do you think it might have worked in the way you had desired?
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
