Old 04-22-2014, 09:47 PM
I was looking at the bolt that goes down through the arm that the idler pulley is mounted to. Some of the later decks had a grease fitting in it. You could drill and tap it for a fitting.
HMMMMMMmmmmmm
Overall, IH did a pretty good job on the cubs, but there were a few things that could have been done better, for instance, the mule drive pulleys and that idler assembly on the decks should have been re-grease able.
Only thing better than having a Cub Cadet is USING one
Old 04-27-2014, 07:01 PM
This is what I was taking about for your deck.
http://www.onlycubcadets.net/forum/s...852#post257852
See post # 70 3rd pic down
Old 04-30-2014, 10:04 PM
Thanks a bunch, Sam. That is what I thought (I know..I know. A verrrrry dangerous thing ) you were describing. I'll drill that bolt that way when I replace it next winter/spring.
