Old 05-21-2014, 09:18 PM
Congrats on the 1650. A spring assist (assuming you don't have one) would have been a cheaper alternative IMO.
Old 05-22-2014, 01:09 PM
Donovan M.'s Avatar
Actually I didn't just find one, I had a nos spring from my dealer. The valve still had both shims, so I left them in there.
Donovan:
62' Original-fenders
Old 05-22-2014, 01:37 PM
Well, then I would say you replaced it. Not "installed a stronger one". Big difference.
Old 05-22-2014, 09:23 PM
Gotroxblazer Gotroxblazer is offline
You can use a spring assist with an electric lift? I thought about that, but i wasn't sure if it was possible.
Old 05-28-2014, 04:30 PM
I had an idea today about drilling and tapping the "plug" that the spring sits in and putting a set screw in to adjust the pressure? Bad idea?
Old 05-28-2014, 05:26 PM
It will leak. Just buy a spring kit. Or shim the old one. It's not hard. Why go to the time and trouble? Have you put a gauge on it? Are you sure that is really the problem?
Old 05-29-2014, 05:51 AM
Yeah, I thought about the leaking issue too. I haven't really messed with it. Been busy. I'll do like you said and get a gauge on it. I just get crazy ideas while I'm at work. Thanks for keeping me under control!
