but there is always a first time.
Up to 534 and counting... I give up updating my profile! |
Let me correct myself. It may not need to be done, but should be done.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
I have no idea what you're even talking about.
What is it and how do you do it? Why is it important? |
http://www.onlycubcadets.net/forum/s...ad.php?t=31329 |
Finally got the old girl charging again. I don't think I needed to replace the voltage regulator, I believe what did the trick was just cleaning up all the connections around the regulator. Live and learn.
actually if you look through the schematic all the way when you start to crank, it self polarizes itself. that's why you should never really have to do it
Good job on getting the Cub rolling again!
From what I have seen here, most electrical problems ( short of someone hacking the wiring harness ) are due to corroded connections. I have sometimes seen crimp terminal connections where the wire has corroded away from the crimp, and the wire is only holding on by a crimp on the insulation.
Only thing better than having a Cub Cadet is USING one
