Those are the good spindles looks like someone has the seals in wrong. They are supposed to have the lip facing out so when you grease them the old grease is expelled.
timken style bearings are a two piece bearing the seal is holding in the center part that the shaft runs thru. the outer race in press fit in the spindle housing from each side usually against a lip to set the depth. those will have to be pushed out, usualy a punch from the opposite side will do it. here is a pic of a timken.
Cub Cadets & IH tractors 1811 - 1090 hours 1872 basket case, rebuilding. #1 tiller 1 Farmall regular |
Thanks everyone! Worked fine.
Cheers, Jeff
