Old 02-26-2010, 01:54 AM
Thanks for all the responses Ok now where to get the beet juice from?
Thanks for all the help!
Old 02-26-2010, 10:49 AM
rwire125 rwire125 is offline
the beet juice is called rim guard, and i just had my rear ags fill and new steel valve stems installed for 57bucks but prices where all over the map so pays to shop around
Old 02-27-2010, 07:53 PM
squatch squatch is offline
I want to do rimguard on my new ags but the local dealer is the most expensive place are for anything. JD dealer. Want's $60 labor per 2 tires + the rimguard. I'm going to keep checking around.
Old 02-27-2010, 08:05 PM
aagitch's Avatar
aagitch aagitch is offline
you'll need to keep looking. The place I used charged 50 bucks total for both tires including labor. A place about 30 miles from there wanted twice as much!
Old 03-01-2010, 12:02 AM
cubby cubby is offline
i use the same as my large ih tractors (cloride)
Old 03-01-2010, 08:05 AM
I would not recommend using Calcium Chloride, as it will completely destroy wheels. There are much better solutions today as have been mentioned. You don't want this to happen:
Old 03-02-2010, 03:18 PM
BanditCub BanditCub is offline
RV antifreeze works great, doesn't freeze, you can buy it fairly cheap in the fall (everybody has it on sale) and it seems heavier than plain old washerfluid. We use it in radiant floor heating systems so the iron pumps don't corrode.
Red '84 Cub Cadet 782
50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd.
