Old 05-28-2014, 10:48 PM
PaulS's Avatar
PaulS PaulS is offline
Putting a fan on the front of the engine blowing back will most likely make things run hotter as the normal flow of air on all my cubs is from back to front. The advice to keep everything as clean as possible is golden. Any debris, crud, etc has a tendancy to hold heat and if bad enough restricts air flow. On my 2084 super I take the cylinder shrouds off at least once a year and thoroughly clean all the fins and then replace them of course. I ran without them for a short while and the engine seemed to run hotter without them.
Old 05-28-2014, 11:26 PM
OffTime's Avatar
OffTime OffTime is offline
Your not going to hurt your motor. Run it with 30wt oil and forget about it. I usually try to blow out the engine with it running at idle from the front. Grass builds up from the back side. In combination with the engine running blowing forward, and compressed air blowing back, you'd be surprised how much grass is stuck in there that will come out. Keep it clean, it will be fine.
Ditto.
It only take a few minutes at full load to bring the engine to full operating temperature. If everything is clean it will handle the heat. I usually run 10w-30 oil in mine no problem.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-28-2014, 11:32 PM
Originally Posted by larry03061976 View Post
Not to jump a thread but could you put a small electric fan in the grill?
NO! Someone on here tried that...... it melted the fan.
Old 05-29-2014, 08:59 AM
jimbob200521's Avatar
I remember that post!
I tell you what I need, another weekend of nice, cool weather so I can pull the engine and give it a good cleaning. That, or a nice PTAC in the garage to take the humidity out of the air. Hmm...where to find a used PTAC
-Ryan
Old 05-30-2014, 05:24 AM
nikster's Avatar
nikster nikster is offline
What I do
No matter what I use a leaf blower After EVERY cut of my lawn, deck, motor . No matter what!
I also use synthetic small engine oil 10-30-30 W. Runs about 12 to 15deg. cooler. I posted the results last year on a 95deg. Day last year. Comparing a 35min. Cut & changing oil & doing it again.
But was told by a friend that it would be better to give the old cubbies a break after every 30min. On a 95+ day. So I do just to be SAFE.
But it's your cub------ DO WHAT YOU WANT!
I'm anal.
NIK.
Old 05-30-2014, 05:26 PM
I tried the compressed air into the front while running.
Tip 1. Keep away from the muffler/exhaust elbow. Not speaking from experience, something I had to keep telling myself while it was running.
Tip 2. Keep away from starter belt/pulley. See explanation above.
Tip 3. Watch out for the flying crap coming back into your face.
I can't believe how much came outta there. Good tip J mech
I also found out that I can clean out under my deck (sorta) by driving it up on ramps. Beats taking the deck off. I don't know why I didn't think of this before.
Old 05-30-2014, 10:07 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
I guess the fan is out then. Another dumb question. How about straight lucas? Lucas actually recomends running it straight in small engines. I know its expensive, but should last longer. I run synthetic in EVERYTHING, but also add lucas as an extra precaution.
Old 05-31-2014, 02:21 PM
Tried the same thing here with a leaf blower, worked alright. I'm sure it'd work better with an actual air compressor, though
I'm sure someone will chime in with a more technical answer but I personally wouldn't. These engines have lasted 30+ years on straight 30wt and they're still going strong. As far as I'm concerned, don't fix it if it ain't broken
-Ryan
Old 05-31-2014, 02:49 PM
FWIW and others have stated, keeping it clean and full is really all that's needed. I used a 782 back in the day for 8 hours of mowing duty a day with no issues. Good luck and have at it!
Old 05-31-2014, 03:00 PM
Yep, as long as the fins are clean and you have decent oil in it no reason to worry.
