Old 06-08-2014, 12:23 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Desperate times, desperate measures
Old 06-08-2014, 11:03 PM
Nightow1 Nightow1 is offline
Finlay saw it tonight, Neat idea. I like the simplicity of it. Should work out great. Now just to see it run
Old 06-11-2014, 11:04 PM
FWIW, I had to pull a half shaft out of a FWD transmission with 12awg and a slide hammer somewhat similar to what you did. I couldn't believe it worked! I may try the same thing on my wheel.
I'm looking forward to the end of your build. I've been day dreaming of P/S on my 1650 since the day I brought it home.
Old 06-12-2014, 12:09 AM
Rescue11's Avatar
The thhn was layin on the shop floor next to me when I was looking for rope. After I used it I realized how nice it was to my steering wheel!
Between work and ambulance runs, I have not had time to do anything with the 1450. I plan to start in again Saturday with hopes of finishing the mount for the hydraulics, finish the cylinder mount and extend the scv lever arms.
Once I reach that point, its I will have these parts to finish.
Plumb hydraulic lines
Thread the hyd cylinder ram
Build a new drag link
Install in line ball joint and adjust
Test after fixing engine, motor mounts, re-installing said engine and mounts
Nightow1 seems to think I should tear it back down, clean, and re-paint. I kinda agree, but have not gotten over the hump yet on the idea... any thoughts?
Old 06-12-2014, 02:31 AM
Finish the build then take it back down for paint if you like once all of the mechanical gremlins are worked out. You might even want to use it for awhile first to see if you want to change something. Custom anything is always an experiment.
Old 06-12-2014, 09:24 PM
Rescue11's Avatar
Yeah, kinda what I was thinking. Just not sure if Im ready to tackle that big of a project at this point!
Old 06-29-2014, 11:06 PM
Rescue11's Avatar
Finally got to work on the 14 yesterday. I got all of the steel lines cut bent and installed from the pump to the column and spool valve. Got the lines for the steering cylinder made, and had new ones build for the lift cylinder while I was at it. All that is left for hydraulic lines now is to tie in the front and rear outlets to the scv.
After that, I need to finish the steering cylinder bracket, make the drag link, shem the front axle, hook up the hydraulic levers re-install the engine and test it out! Ofcourse I'm leaving smaller stuff out, but y'all get the picture.
I'll have pix tomorrow.
Old 06-30-2014, 01:08 PM
Rescue11's Avatar
here are the pictures as promised
Old 06-30-2014, 01:17 PM
Lookin' really good!
Isn't it fun bending all those lines!
Old 06-30-2014, 01:26 PM
Rescue11's Avatar
Oh yeah, it really tries a guys patience. I have never had to put bends quite like these in refrigeration tubing. I'm just hoping there are no leaks!
