The clicking is the starter solenoid, it is possible the the solenoid is bad or the battery isn't charged or that there is a a bad ground, or not sufficient voltage getting to the starter.
Unless the battery is bad, Sam Mac, is exactly right, follow his instructions and all should be good.
I'm sorry I have not yet had a chance to check and answer each reply! Started a new job, and I'm looking forward by this weekend to check things out with many helpful suggestions. I'm confident we'll have her running shortly!
Many thanks to Only Cub Cadets! I'll keep you on the update,......
I had removed the 1450 from the shop, and parked it in the shade. Came back a while later to return the tractor, when I hit the key, I thought I heard a "double" start, or something weird like that. { like maybe I lost hold of the ignition switch key,...which did happen } The gent from OCC whom I got the 1450 from, states that the ignition switch is genuine Cub Cadet from a local dealer. It looks bran new,..... hummm,...............
I had a loose connection on the PTO switch give me an intermittent crank condition. I'd get a test light or voltmeter, and a schematic and follow the power to find out where you lose it. If you have power at the starter, it is bad (check grounds too.)
Philip 1450, 1015, and a pile of parts. |
Congrats on the new job. Check all of the connections, Check the PTO switch, Mine gets a little funky at time (just flip it on & off with the key in the start position and see if anything changes). if all else fails try a large screwdriver that you don't care about across the 2 large solenoid terminals.
Greg
"If I can't fix it, I can screw it up so bad no one else can either" |
Just the fact that the solenoid clicks rules out the possibility of the ignition switch and safety system in my mind. Sounds like battery problems, connection problems, bad solenoid or starter problems. Just my two cents.
Matthew B ![]() 1972 129 w/hydraulic lift and head light option soon to be repainted |
The same thing happened on my 1450 a couple of years ago and it was a dirty connection at the Battery.
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
+ 1 Sam Mac idea ! |
