Old 03-01-2010, 03:43 AM
ajgross ajgross is offline
Inactive Member
If you want hydraulic lift on a tractor, you would be a lot better off trying to find a 782 or something that already has it on there. The biggest reason I say that is because you would have to change your rockshaft and it is a REAL PAIN to remove.
AJ
Old 03-01-2010, 10:49 PM
spumco spumco is offline
I just overhauled the carb and found the main needle with a bent tip from some hamfisted PO along with a few crusties and a poorly set float level.
I had visions of the needle tip fracturing as I gently rolled it straight on a surface plate. It's as good as I can measure it, so fingers crossed.
Also cleaned up the ground wires and checked the gen wires as suggested. Grounds were corroded, but the gen wires were fine.
Almost forgot to turn the fuel valve back on just now... That would have driven me insane.
It's a little late now to fire it up, but I'll report back tomorrow with the results of tonight's fiddling.
Again, thanks to everyone for the help.
Old 03-02-2010, 06:37 PM
Sweet success.
New plugs and a carb overhaul seems to have done the trick. Ran like a champ up and down the street, along with some iceberg ramming to really load the engine up.
No missing, no bogging. Big thanks to whoever it was that suggested Autolite plugs.
Now I just need to finish the mower deck by spring.
Old 03-02-2010, 06:40 PM
murphycc
Guest
Posts: n/a
Originally Posted by spumco View Post
Sweet success.
Good, glad it worked out for ya.
Scott
