You definently have a tuff growing season. I would look into a summer/drought blend grass.
I'm sure Scotts and other seed producers have some sort of blend. If you use mulching blades and don't cut grass that's 6 inches tall you shouldn't have any thatch build up.. But I thatch not to brake it up but to scratch the dirt/sold and pick up the blades of grass so the grass seed gets to the ground. Then use a drag rake to (old fence) level everything out. You should use a roller to get the seed contact with the ground. Water once to get the seed going. I don't think you need to core aerate before seeding. Also leave the grass 3.5 to 4 inches high.. Keeps the soil cooler and moist longer. Plus it helps to keep the weed seeds from germinating. Just my .02$ |
I overseeded last fall with Rebel Southern Blend, it was the first to go since it was young grass without a well established root system.It contains Rebel 4 and Rebel Exeda cultivars, which are fairly highly rated. I don't think there's any fescue type that will withstand these conditions without going dormant. KBG is better about full sun but requires more water. I'm considering adding 10% KBG this year, although it's not recommended for this area. But I'm definitely going to give it my best and use Bullseye seed, which is the top performer for the area in NTEP tests. Maybe I should look into replacing Tall Fescue with Zoysia.
Are you being serious? Will the seed actually come up in the spring?
It would probably take the heat and lack of water better.....
Why does everyone in the midwest make such a big deal about getting it out in the spring and covering it with hay and watering it and everything then? Seems like a huge PITA so I never bothered...
If I knew I could just toss it on the ground on a clear day in January I'd have been planting some more grass long ago! |
![]() It's really NBD. Works too! The straw isn't for the seed. It's for the soil. So it doesn't wash away until the grass is established. It also starts the thatch bed. |
Shows what I know about the topic!
I just watch what my neighbors are doing and I'm like "it grows fast enough"... Now I have some places that I must repair due to plumbing issues. January it is! |
http://www.agry.purdue.edu/turf/homeowner.html |
An important thread because, well, if the grass doesn't grow fast and thick then we would need fewer tractors......
