) for the past couple years, but I think the next tool I buy will be a bench grinder. That way, I can go fairly light but still make sure I get the correct angle.The big thing with sharp vs dull blades is HOW it cuts the grass. Sharp blades cut the grass clean and encourage re-growth. Dull blades "rip" the grass (think blunt trauma), and that's harder for the grass to deal with, to "heal" from. Which would you rather heal from; a paper cut or a gash from dull butter knife? At least that's what I've always heard and been taught by my pa, his pa before him, and farmers I've worked for
-Ryan
This brings up another question; what KIND of blades does everyone use? Regular (flat blade) or mulching (angled serrated back edge)? I've had both but have never really been able to tell a difference.
![]() ![]() vs
-Ryan
Flat blades. No fancy mulchy ones, etc. Sharpening on the deck, with an angle grinder, until they are so shot I need to take them off to replace them.
Which would you rather heal from; a paper cut or a gash from dull butter knife? At least that's what I've always heard and been taught by my pa, his pa before him, and farmers I've worked for? -I've been told what do you get cut from, a dull knife or a sharp one? A dull one because you are trying harder.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I use Rotary blades. These are nice heavy blades.
Don B, USAF 1962-1968, Ft. Wayne, IN |
You should sharpen your blades on a bench grinder, then balance them, balanced blades are easy on the spindle bearings.BTDT
Up to 534 and counting... I give up updating my profile! |
I've gotten pretty good at it but still want to use a bench grinder. I may be pretty good at sharpening blades, but my angles will never be as dead on as with a tool specifically built for what needs done so I agree; bench grinder is the optimum tool.
-Ryan
I sharpen mine with a flap disc on a 4 1/2" angle grinder. It removes less material than a grinding stone and it's really quick. I always check for balance too. I never worry about removing all of the nicks, just put an edge on it.
I want to make one of these. https://www.youtube.com/watch?v=2uSJCTGiVLw A friend of mine has an old grinder made for sharpening blades but it removes a lot of material.
I like to keep em running and work them. 1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors. |
LOL! Good one!
