Old 07-01-2014, 11:54 PM
cubby102's Avatar
cubby102 cubby102 is offline
Mine does the same when the engine is running. Works fine on trucks just every cub cadets 've tried testing it goes nuts
Old 07-02-2014, 07:29 AM
steveyrock's Avatar
steveyrock steveyrock is offline
my meter did that until I found the coil was sending voltage into my frame and back into the Neg side of the battery.Make sure your high voltage is not leaking off. Get all it's componants,condenser and it's wire includeing sparkplug wire mounted correctly.Make sure the wire insulation is good the entire length and check the coil for any damage.I finally got a steady reading on my meter after chaseing down those issues.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
