Old 07-05-2014, 08:12 PM
Chetman's Avatar
Chetman Chetman is offline
Originally Posted by knucklebuster283 View Post
PM sent about 1641 hitch
Knuckle buster Here's his# (270) 766-2493
KY, USA
I could probably make it work, but it may fits yours perfect
GT2186 & 3205 60",54" & 48" decks
2182SGT 60" w/ dual hydraulics-sold
Craftsman GT 8 spd. 46"- stolen 11/5/14
JD L120 48", JD1025R, 60" auto, H120 fel
'72 Murray GT B&S 16hp twin
Dump trailers,Brinly,plow, disc, cultivator
Box Scraper,spreader,Chains& weights front & rear
Ford 841 & 851 powerMasters,6'Bushog,sickle bar
Farm Pro 2425 6'disc,2btm plow,seeder/spreader, hay spears
Old 07-05-2014, 08:16 PM
Chetman's Avatar
Did you call Bill? I can never find a price on his site. I will soon be finding out how hard it is to put a SGT hitch on a GT. It WILL fit, one way or another. (No, I haven't bought it yet.....)
I found it on the Ruegg site. I sent him a email, but haven't heard back yet. They look like a nice hitch and like the pic of the oem in my book. What's the difference in the Extreme?..Materials, looks, price?
Old 07-05-2014, 09:14 PM
Ruegg does not make the GT hitch only the SGT with the area cut out for the optional pto. They are completely different.
Old 07-05-2014, 09:29 PM
red56turbo's Avatar
The price on Extreme was around $495 last time I looked. Aaron at Extreme does awesome work, don't get me wrong. Ruegg hitches have the OEM look. The lower three point arms look like the brochure you posted and the pic Todd (Oak) posted. They are Z shaped so to speak. The Extreme lower arms look like a regular garden tractor three point. Rear plate is different like Todd said as well. Either will work fine. All depends on the look you want.
Josh
Diesel Cub Cadets...........
Old 07-05-2014, 09:33 PM
red56turbo's Avatar
Here's a link to Aaron's page at Xtreme. Price $480.........
On the left side, you'll have to click on the three point stuff.
http://www.xtrememotorworks.com/Part...rts%20List.htm
Josh
Old 07-05-2014, 10:47 PM
Chetman's Avatar
Angry
I just realized all of my ground engaging attachments are for a sleeve hitch used with manual lift handle. Is there an adapter to use them on a 3 pt hitch.
Old 07-05-2014, 11:04 PM
red56turbo's Avatar
Yep,
Hop on the above website I listed and Aaron sells the three point adapter to use with brinly sleeve hitch equipment. Listed in the same three point area.
Josh
Old 07-06-2014, 08:56 AM
Chetman's Avatar
Question
Ok, next question.. If all of my attachments are for sleeve hitch.. Would I be better off to try and make my hitch work, or get new sleeve hitch and a lift bar for either? I can't think of any other cat "0" equipment I'd be needing.
I would still like to get a 54" blade with power tilt to hook into front hydraulics, but may just be a big wish finding one & can afford
Old 07-06-2014, 10:26 AM
ccpullin ccpullin is offline
You can install a sleeve hitch on a super but there are 3 things to think about:
The upper rear frame is notched for the cat 0 so you would need plates for the frame and remove the rear hitch plate
You would need a long actuator link to the rock shaft
All your implements would be higher off the ground because of the larger tires unless you dropped your lower mounting plate and lengthen your lift links.
A little time investment but you can save some $$$$
View this previous hitch thread for more information on Super hitches http://www.onlycubcadets.net/forum/s...ad.php?t=31940
Old 07-06-2014, 10:30 AM
While all this is mostly true, the distance between the upper and lower links is the same on the super. Just taller tires. And why would he have to remove the lower hitch (drawbar)? It can stay on with the sleeve hitch.
If you have no use for a 3pt, then don't buy. If a sleeve hitch fits your needs, go that route. My is a cat 0 is about 150X better than a sleeve hitch.
