Old 07-13-2014, 12:00 AM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Everybody makes mistakes. We forgive you!
Old 07-13-2014, 12:28 AM
I resemble that statement!!,,,,
So Cad, why isn't it in the picture with the others? You got it hid away in the shed, right?
Old 07-13-2014, 03:56 AM
Maybe he found my $1800 "green tractor" u-joint thread from last week and tucked tail?
Old 07-13-2014, 05:53 AM
yeeter yeeter is offline
Will pick it up today. Closer inspection will determine how big a mistake it was.... (there are two of these, one for 'parts'. We will see. Am pretty confident I didnt lose any money on it). But I had to chuckle - called on one tractor and it ended up being two as a package. And a guy was coming today to pick up a 1650 I had sold, so thought I was working the numbers down and was stable.
Was trying to work my way down to only two (2), dos, tractors. Im failing. They are like tribbles...
Will put a proper post once I have pictures, but this is my first red one.
Old 07-13-2014, 06:02 AM
THAT, ain't a problem, my wife, has a problem!!!!!
Thats awesome! Hmmm... I wonder if in the process of painting a tractor, I painted my wifes mixer, that it would gain more support for tractor paraphernalia....
The only question might be whether she prefers a red or yellow/white mixer...
Old 07-13-2014, 06:08 AM
I want to know, is that two more added to two, or two added to how many??
Well, I guess to answer that I would have to know the official method for what counts as a 'tractor'?
Does it have to run?
What if its a complete frame but with no motor?
What if it does run and has most of the parts, but Im stealing parts left and right off it and soon to be just a frame?
Does a bare frame count? Frame with wheels and rear end as a roller?
The answers to these questions might have an impact on the total number....
(Im on a small wooded lot and need to haul firewood, drag logs, move rocks around (lots of rocks), and snow. And some more snow. Nothing that couldnt be done with a single tractor. But right at the moment I will put my total count at... 6. Or 8 depending how you count) I keep saying I am going to get down to 2.
Old 07-13-2014, 07:32 AM
Saying that, now, THAT, is a problem!!!!!
Only two WILL get you a trip to a shrink,,,,,, you see,, Cubbies are cheap therapy!!
That is how my wife looks at it,,,,
Old 07-13-2014, 08:14 AM
Nice looking fleet John and I know that's only part of the fleet.
This is part of my fleet, since this was taken I've added a 1782 and a 149.
Old 07-14-2014, 02:40 AM
At my house, we define "A Tractor" as: It must "Run and Drive", though some may need a battery and a shot of starting fluid (hard as "heck" to keep that many good hot batteries in that darn many tractors) to get them going.
"Run and Drive" is defined as: Starts and runs with a key or possibly jumping the solenoid. Must have a throttle cable, although does not necessarily need to have the choke cable hooked up (but only if the choke lever can be reached from the drivers seat). Enough tires must hold air to "limp" it to the nearest air hose from where it normally resides without "breaking the bead" (although this is not preferred). Gas tank, fuel line and carburetor must not leak (although the "shut off" can drip a little while it is being turned). Lift levers, hydraulic lifts or electric lifts must be in working order. PTO's must be operational, UNLESS unit was not so equipped from the factory, ie Originals, OR if the tractor is designated as as a working unit with an attachment that does NOT require a pto (for instance, a designated blade tractor). All others are considered to be "Projects", "possible project tractors" or "parts tractors" until such time as they have been robbed of enough parts that they can no longer roll or otherwise be towed from one end. Then they are considered "just parts".
If you are any kind of serious about "getting it down to 2". Then I would have to say "YES, you are in need of professional help".
Old 07-14-2014, 07:55 AM
[QUOTE=yeeter;273689]
Was trying to work my way down to only two (2), dos, tractors. Im failing. They are like tribbles...QUOTE]
Exactly like the Star Trek Tribbles...They do not talk too much
Only thing better than having a Cub Cadet is USING one
