Old 07-22-2014, 03:18 AM
OR you can loosen the nut, spray with penetrating oil and drive around as you normally would (spray with penetrating oil every day or so) and it will come loose.
Old 07-22-2014, 07:50 AM
rebel715 rebel715 is offline
Thanks for the replies, I may just lift the tractor and do the adjustment from below without pulling the steering column. Hopefully that will adjust the steering play.
Thanks!!
1977 IH Cub Cadet 1000
Old 07-22-2014, 03:09 PM
I have VERY CAREFULLY used this same basic trick to remove stuck wheels on cars before by slowly driving up and down the driveway while turning sharply with the lugs slightly loose, but on.
That's probably the method I would try unless you're in a big hurry.
