Old 07-25-2014, 11:13 AM
I like lemonade...
run a clean piece of paper between the points and see what happens.
Lol, ok will do.
Old 07-25-2014, 11:14 AM
Have you verified "test #2" as stated in SDD's post?
Old 07-25-2014, 12:29 PM
red56turbo's Avatar
I like lemonade...
Money works good, too. Might be dirty though. Bennies work the best, but a single works in a pinch. No kiddin'. When looking at a cub, I pulled out a bill, ran it between the points, and she fired right up! Almost cost me that extra bill for the cub though.
Josh
Diesel Cub Cadets...........
Old 07-25-2014, 12:35 PM
I like lemonade...
That's cool josh.
Old 07-25-2014, 12:36 PM
Not yet I haven't.
Old 07-25-2014, 05:49 PM
Nick thank you for acknowledging my post. My test light flashing on the negative side method is testing the positive in to the positive side of the coil and through to the negative side. With no negative applied to the coil (points closed), positive potential will be on both sides of the coil, hence the test light being lit on both sides. When points close, test light should go off on negative side only, but still stay lit on positive side. So, when cranking, points opening and closing, test light should flash on and off quickly on negative side of coil if there is good continuity through points and ground side. See Jons technical Tuesday post on static timing, uses test light for exact points closure.
Old 07-25-2014, 08:48 PM
Thanks mike, the test light doesn't light up at all when I touch either side of the coil while cranking it.
Old 07-25-2014, 09:26 PM
You need to trace the circuit back to your key switch, ignition terminal, maybe bad connection there or bad key switch. Battery positive comes in on batt terminal of key switch then out to coil positive with key on as well as cranking position, has to be there or no sparky
Old 07-25-2014, 09:56 PM
good advice Alvy,How u making out there Nick?
Old 07-26-2014, 07:24 AM
I will continue on it today. After I go look at some cubs for sale....
