Old 07-27-2014, 12:42 PM
yeeter yeeter is offline
And the winner is......
Fluid/Filter.
The fluid was pretty dark. Some clumps in the bottom but not as bad as the last one I did. The filter seemed to me to have been changed approximately..... never. (rusted can, and stuck on there good). It was a red filter and hard to make out the writing - possibly Case? (will inspect this a little closer)
New filter, new fluid, and it runs/drives as smooth as anything.
Old 07-27-2014, 01:53 PM
SS5150's Avatar
SS5150 SS5150 is offline
Dang,! Lol....glad to hear its going again
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 07-27-2014, 02:04 PM
Hmmmmm....... yet another fix with fluid and filter.
Red filter= Baldwin
Old 07-27-2014, 04:38 PM
Red filter= Baldwin
Yep. And more great advice from you Jonathan.
Thanks to everyone here for some great insight/advice. I feel like I am learning some things....
Old 07-27-2014, 06:09 PM
You should also clean all the hydro pump fins while you are In there.
Old 07-27-2014, 11:26 PM
cubby102's Avatar
cubby102 cubby102 is offline
Glad to hear ya got it fixed. Them clogged filters can cause all sorts of headaches. Mine would run good and strong for about 50 ft then slow down and stop. Let it sit over night and itd do the same thing...this is a great site filled with many knowledgable and helpful people. Tis the reason I keep coming back
Old 07-28-2014, 07:12 AM
Old 07-28-2014, 09:00 AM
ravenseye ravenseye is offline
When my 782 first had problems, it would sometimes not roll forward when I wanted it to. I couldn't figure out why. I'd try it forward, then reverse, then forward again and it would work. I assumed it was purely mechanical and while it was annoying, I could live with it. Then, I decided to change the fluid and filter. I was adding a hitch and since I was back there I figured I'd just get the job done. Never had a hiccup since.
