Old 08-06-2014, 05:20 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
google
"blasting media new jersey"
and pick a vendor near you, call and discuss your needs.
There are hundreds of types.
You can even get some types at TSC Stores.
Old 08-06-2014, 06:04 PM
cc_bob cc_bob is offline
For the flash rusting...
Pick up a gallon of this from Home Depot, it's about $15.00 and a little goes a LONG way. You can dilute it and wipe your parts with it as soon as your done blasting. It will remove the flash rusting and stop it for a couple days too.
The active ingredient is phosphoric acid (a weak solution). You can go to the parts store and buy the same thing but it will cost a lot more.
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 08-06-2014, 06:11 PM
Originally Posted by garnold View Post
So any tips on what type of sand to buy? I've never done this before and there are quite a few options. Sand of different grits, walnut ?!?, glass UGH!
I've tried the stuff from TSC, total crap, Lowes masonry sand, not too bad, I am now using sand from the local NAPA, so far it's the best. I'll try to remember to get you the name of it.
Old 08-06-2014, 09:44 PM
garnold's Avatar
garnold garnold is offline
Nice tip. I'll pick some up.
Old 08-06-2014, 09:46 PM
garnold's Avatar
Thank you Sam. I'll run over to the auto store tomorrow and see if they can help as well.
Old 08-06-2014, 09:58 PM
Sand...
you must wear proper protection when using it as a blast media.breathing in the dust will cause silicosis.
It is a one time use.
If you using it with the pressure washer it is fine.
I use black beauty in my gun.you can get a few uses out of it.
Valley mason supply in vernon has it in different grits.
still need protection though.
Up to 534 and counting...
Old 08-06-2014, 10:13 PM
garnold's Avatar
Nice Lew, thanks! Yeah I plan to get one of those respirator things
Old 08-07-2014, 06:15 AM
If your using a pressure washer blaster no need for a respirator, no dust. But you will need face protection and a rain suit, ask me how I know.
Old 08-07-2014, 06:19 AM
Old 08-07-2014, 10:39 AM
Berwil's Avatar
Berwil Berwil is offline
.......and a rain suit, ask me how I know.
Good thing you had one left over from your previous career.
Bill
