Old 08-06-2014, 08:55 AM
GrotenhuisCubs's Avatar
GrotenhuisCubs GrotenhuisCubs is offline
Ok thanks, guess I will get the big pipe wrench out and a pipe and a BFH!
104 puller, 1200 puller, 1450 toy!
Old 08-06-2014, 05:35 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I've never broke a block. did break one or 2 elbows but I've probably taken more out than most, at least somewhere in the 80 to 100 range. I'm not gentle , lets put it this way, I've broken the handle off of 2 pipe wrench's already hitting them with a hammer.
Old 08-06-2014, 10:05 PM
it was pretty easy to get the elbow out of the 100 i was working on earlier today, it just fell out when i took the muffler off.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-06-2014, 10:33 PM
Yeah, see that's the luck I usually have too. Broken.
Old 08-06-2014, 10:46 PM
actually it wasn't broke, the threads were a little chewed up from rattling in the block so i cleaned them up and threaded it back in, it went in good and tight so hopefully its good to go now.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-06-2014, 10:53 PM
Default Thanks Don!
That's what I wanted to hear Don! The big stuff is coming out! Lol
Old 08-07-2014, 01:29 PM
sawdustdad's Avatar
Originally Posted by dvogtvpe View Post
big pipe wrench and a big hammer. usually they come out
this has been my experience. They've all come out for me.
Old 08-08-2014, 01:25 AM
PB and let it soak for a couple days. Get the ring loose and spry it down again.
I used a pipe wrench and actually bent the elbow, but I'm rather impatient at times. I found a good supply of pipe at Home Depot.
Old 08-08-2014, 03:44 PM
What I have found works for me for really stuck bolts, nuts, flanges, etc.
Soak for a couple of days with high grade penetrating oil of your choice..PBBlaster, Kroil, etc. Smack with hammer a few times to help work in the penetrant.
Heat with torch, then SOAK with penetrating oil while still hot.
Repeat a couple of times, then repeat next day. Wipe up excess penetrating oil before re-heating. Should come loose with a few days of this treatment.
Only thing better than having a Cub Cadet is USING one
Old 08-08-2014, 06:04 PM
dvogtvpe's Avatar
soooooooo, you ever get it out?
